I have used the old Ariens snowblower headlight kit that comes with a AC bolt on generator that bolts up to a special Recoil assembly. The recoil has a hole through the center to accommodate a shaft that mounts to the flywheel nut, the shaft is what spins the generator. The generator is AC voltage and has a special plug that plugs onto the Gen. The plug must have some sort of resistor built in. if you want to run it just for lights that's fine to use it as it is. BUT if you want to convert it to DC voltage remove the plug and install a 1-amp diode to one terminal and ground the other terminal. At high rpm it will put out enough voltage to charge a small battery for 12v DC electric start. Check out one I installed on my MTD custom. Here's a Video. These Gen's & recoils are kinda hard to find. I have 3 that I'm keeping. Check ebay & your local Mower shops for old Snowblowers with the light kit's https://youtu.be/Q9F_v33NQCU
