I am seeking advice, having never attempted to build an engine for performance before. I have rebuilt my 5hp briggs in the past but its time for another go around. This time I want to aim for "bang for buck" performance as the engine is going back on an old go-kart. Last night, when I took the valves out I did not have a spring compressor so I used the screw driver method. In doing so I damage the bottom of the valve shaft by hitting it with the screw driver causing a bur. I tried knocking down the bur but could only do so much. When I removed the valve, the bur scratched the valve sleeve. Should I be worried about this in anyway? If so is there a way to re-sleeve the valves or should I look into getting another block. Also, the crankshaft has a little side-to-side play in it. Is that typical or is it time for another block anyway. Is anyone in the KC area that knows of a good machine shop for my build or that would be willing to offer assistance for my first time build?
