Thanks guys, I am getting it pretty well finished but wish I had ground off the casting ridges on the aluminum frame more before I painted it. The center ridge on the frame under the engine won't let the engine set down quite flat on the frame, the jackshaft mount bracket had the same problem. I don't want to mess up the frame paint so the engine will need some thin shims under it to level it up so the mounting bolts can tighten down evenly.
