I got a little done on the wards project, just starting to mock up the rear wheel, engine mount, Tav2 ect.....
I decided to try a Tav2 on the clone, if it doesnt hold up I'll go with a Cheetah or Stinger clutch..
Engine:
6.5 clone
arc rod
arc flywheel
flat top Honda piston
.080 milled and ported head
.010 head gasket
SS valves
Chromolly push rods
285 lift 250 duration cam
Taylor 8mm plug wire
6 degree flywheel key
Frame:
Wards/Columbia
Rear cut off, flipped and extended an additional 3", widened 3"
New engine plate (will be mounted at 10 degrees approx)
Engine:
6.5 clone
arc rod
arc flywheel
.010 head gasket
SS valves
Chromolly push rods
Frame:
Wards/Columbia
