Thanks Phil,
The crank is a points crank for a non bearing PTO cover, I need that turned down to accept a bearing cover.... I took a shot in the dark by ordering this crank with the hope that it will work with just turning that section down... The bearing cranks are NLA new so hopefully this will work.... I should have the crank sometime next week so when it comes in I can compare it with the old one and see if its going to work... The old crank is worn out on the rod journal pretty bad, it must have knocked pretty good the last it ran. I will let you now when it gets here and we can take it from there.
Thank you, Randi
