Why simply remove the governer from a clone and leave it stock? Did the easy starting and reliability bother you? I can totally see doing it on a purpose built race engine with billet rod, flywheel, big cam, carb and pump etc. as these engines are generally started with an electric starter and once they are running they are fine, hell some are mild enough to pull start but have been meticulasly tuned for performance and reliability so I understand that! But simply removing the governer from a stock clone makes no sense! It renders them hard to start and keep running without skillful tuning on the carb, and some timing probably would help but still! I know I'm running this method into the ground but it is so stupid simple everyone should at least try it!
A smaller diameter stiffer spring, piggybacked like this allowing the engine to start and idle as intended, but limits or bypasses the governer by limiting the pullback if not eliminating it all toghether! It costs a buck or less and that particular setup allowed me to go a best of 42mph with the stop screw backed out on a Older DB with 66 tooth sprocket and a 12 tooth max torque clutch @ 4500 RPMS! Try it if ya got a stock governed unit and feel the difference, no surging at all and great performance!
