Ok, just wondering, My motor says that it is 9/16 keyway. And all the clutches I have seen for sale say they are 3/16 keyway. Is this going to work? Dont know much about engines just wondering, thanks
What would be the best clutch to use for drag racing?
My motor is basically a 12.90 jr dragster motor, and the bike and I together are about 260lbs.
Thanks
So I just won this,
eBay Motors: Honda Odyssey FL250 FL 250 Stock OEM Salsbury Clutch (item 260385470862 end time Apr-05-09 14:39:37 PDT)
I seen an odyssey clutch listed on ebay as having a 1" bore before, So I figured this one may be.
But I'm not sure now, I think It might be tapered. Do...
i am currently running a #420 chain on my baja heat. :grind:i have mounted a gx390 and have moddified the clutch:hammer: that came with the bike to work on the gx390:weld:. now i want a torque converter but i only see them advertised for 1"inch bore #35 chain or #40/#41 chain. i need to know...
I have a new old stock Horstman Manufacturing torque converter clutch that I plan to mount on my Speedway. It's very similar in outside appearance to the Comet drivers. The main difference is the Comet has 2 rows of small springs around the center hub and the Horstman has only one row which is...
