Any ideas?
https://youtu.be/T9JyvHAXbdc
Not sure why this stupid thing won't run, it seems like the fuel line is clogged or the carbs gummed up but I won't know until I tear into it. It ran great last time it was out, and I don't understand why the fuel line would be clogged or the carb...
Ok so here is my problem. Engine was running good with timing at 30* but I adv it 2* in search of the extra bit of power (arc adjustable flywheel) and the bike did not run good. I set timing back to 30 and now the engine blows flames and dies when you hit the throttle hard. I have gone thru...
Ok everyone I am making another custom minibike. Welding a frame, fabricating parts, you know. Anyways I am planning on putting on lights and a horn, and want to get it registered. However, I can't just keep changing out batterys and I want to be able to drive without fear of dying. So my...
i just rebuilt another 5hp briggs flat head and it cranks and runs fine, but when you give it gas it imedietly dies,, any ideas?? also it semms to flood real easily:shrug: maby just a bad carb?:shrug:
I am thinking I may need a rejet of some sort, but what do you think?
Motor is completely stock, with a helper spring on the governor spring, stock air filter and airbox, stock exhaust pipe but muffler box is broken off. Essentially just a closed end pipe with 3 holes drilled in the side of...
Well for the past month it has been over 100 degrees here in Texas. Yesterday, while on the way home from work my car reading was 111 degrees. Whats the weather been like in your area? Sorry for the crappy cell phone pic.
My honda is having problems now. It runs fine at idle. When i give it a good amount of gas it dies out. all the gaskets are new and sealed. I think its has to do with the carb because everything else is working fine.
If its is the mixture and i have to tweak that, Can someone tell me where...
cranked and ran my new 6.5 h/f clone. ran it down the block and it died. let it set and cracked it off again and down the block again and it died again. cliped the yellow wire coming out of the crankcase thinking it the oil sensor..it's 2 hrs. later and it still won't start. HELP...
