Hello, I will be installing 26lbs springs in a non hemi predator and would like to know how can I measure the spring install height without any special tools? Thanks
Howdy y'all!
I have looked for weeks to match this little bugger up to SOMETHING!
There are many like it but nothing matches it to a tee. :no: HELP!
Thanks for looking and someone please put an end to my madness.
Hi everyone,
My friend Scottessey hooked me up with a Cal Kart Invader frame and a Briggs & Stratton 4 cycle 5 HP I/C series engine.
I was wondering if anyone could refer me to a rebuild kit for the engine and or any other components i may need to get started up.
This is my first...
I recently bought new replacement parts for my carburetor, and once i put everything together and plugged the guy back in it would start to leak oil. From what im pretty sure the source of the leak is coming from the little hole in the picture. Im currently taking it apart again to see if i...
Hi please can any one help i have a UK made mini bike/scouter manufactured by K>R>WIGLEY&C)>LTD IN LEATHERHEAD SURREY ENGLAND MODEL 105 b3 if any one can give me any info on this mini bike it would help
diamond leesorry this is in the wrong place how do i move it to (what is it)
I have a baja heat with a fork seal that is failing. There is oil coming out of it and it dosen't look good. I want to replace it but I can't find replacements. Does any one know the size of them so I can get some new seals.
If you're making a bike from scratch, what do you guys use for the neck tube connected to the steering fork. Cause I made my chopper from scratch, and then I just used a piece of pipe with a bolt through it, and that didn't work too well cause it cracked and warped.
So if I wanted to order...
