I don't have any experience with small block Tecumsehs so need a little hand-holding here. Is the breather housing one piece or two? Just looking to replace the element and it appears pulling it out of the narrow slot is not correct. Also, the housing gasket looks to be sandwiched rather than...
Hoping someone can help me on a problem I'm having. I thought I was on my way to putting a HS-40 back in the mini bike. I picked up a HS-40 motor on a snowblower. Engine ran good. I already had the lighting coil and flywheel from 4hp Tecumseh. Decided to put a new headgasket on it , but thought...
Anybody know what size of tecumseh this is. I can not find anything. Older hs-40 lighting col and flywheel is on it. Shroud has been modified. Thanks Garry
Question... I have a 71 Rupp Hustler with a HS-40 how much air should be coming out of the breather? I have a lot. More air comes out of the breather than the exhaust than the tail pipe at idle.
Any suggestions.
Couple of pics of the bike.
Thanks.
I usually try to figure out these problems myself, but after 2 days of working on this problem I am stumped.
I have a early 70's HS-40 that was rebuilt around 7 years ago but never started. I changed the oil, checked for spark and put some fresh gas in it and nothing. Found the timing was...
