info
  1. Biffmini
    HS50 mod info wanted
    I'm looking to educate myself on HS50 mods. Any ideas on books, sites with good detailed info, or OldMiniBikes threads that would help me learn!!! I've read a few threads and the ones I've found so far are a bit vague, for my level of knowledge. I know there's plenty of help here, I just don't want to...
  2. jpdriver1
    looking for trail blazer info
    I have found my trail blazer is missing a cap or bearing for the left side of the front axle. Anyone have a closeup pic of this assembly or a spare cap? Any and all help appreciated. thanks kevin
  3. Abit1322
    Looking for info on this wheel.
    Hello OldMiniBikes friends, I bought a bike and this wheel was on it. I'd like to use it on another bike of mine but I can find a match anywhere. Anyone know the make or what bike it came on. Any info helps. Thx in advance
  4. mlanzoni
    Briggs parts and install info please ???
    Hello all, I started looking at an old Briggs engine I have, which has no spark. I tried to find a diagram and parts list, and any information. I came up blank. The number stamped on the engine is 170402 0515-01 7001221. Does anyone know anything about this engine or where can I get some...
  5. G
    Pac mule... Need info on restoring it
    I bought this at an auction the other day, thought it was a Tote Goat, was told this is a Pac Mule. all the jack shaft is gone, a poorly welded on belt pulley replaced what was ever on the rear wheel. somehow i need to find out what parts will make this work and if they are available. I have an...
  6. P
    Any info on this 8hp B&S?
    So my friend gave me this motor, and aside from being an 8hp Briggs and Stratton with a 1" output shaft I don't know anything about it. Will this be a good motor for a mini bike project? I plan on running the gear directly on the output shaft and the centrifugal clutch on the jackshaft. Also...
  7. Belbuekus
    Some hopefully helpful info.
    "What mini bike do I have?" I know I've asked that question a few times. Well while banging around the web I found a couple of websites that might help those of us who are a bit less knowledgeable then the veteran builders identify what we bought or are about to buy. Don't know if they've...
  8. Biffmini
    Trail Horse Info Wanted
    I've Got a hard tail Trail Horse with chrome forks I'd like to put two speed on, I have fenders I can chrome. I looking to keep this one an accurate restro. Any ideas on Mod. I can I can build that fits my starter kit description. Pics. Tips , any research info would be helpful, thought I'd...
  9. patrick2260
    Minibikepaul PH # or contact info please
    Been a long time since I've been on the site. Apparently minibikepaul has been banned??? I use to have his email and pH #. Anyone out there have his contact info ?
  10. Eliminator
    Noresman Sportster S-66, Rocco Products Inc. Minnesota Info??
    Just picked up this antique mini bike, sorta scooter up off of local craigs last night.. I found out what it was on the U.S. scooter museum site and even found some original literature for them on evilbay. Anybody out there have one or ever seen one?? It has a contracting band brake...
  11. A
    Info much needed
    I have a used motor and need info like hp and yr. it's a Tecumseh engine stamped H35-45509M.Ser#9173B Thanks for any help you may be able to share Robert
  12. lostinbaja
    J.C. Pennies/Bird Mini Bike Info Wanted?
    I just picked up a chrome J.C. Pennies/Bird Mini Bike, naturally it needs some work and shining up. Did these bikes come with a Briggs or Tecumseh engine? Anything else you can tell me about it will be appreciated .
  13. L
    Yamaha Chappy where to find info
    FIL just picked up a 80cc Chappy. it is running now, but the carb could use some work. which carb is it? and where to find parts? carb kit, tires, trans shift lever........
  14. smudvapor
    Looking for Sidekick info
    Hey guys. I just bought a Sidekick and I was wondering if anyone had some information on them. Mine has everything but the engine and the seats. What clutch was in it? Any pictures that you might have. Any info would be appreciated. As soon as it comes (bought it out of state) I will take...
  15. Dick DeBuse
    Looking for info on Calaveras Climber
    A friend picked up a Calaveras Climber at Portland and would like any information available. Square tube frame, made in Arnold Calif, has a fluid drive clutch, probably a Bowlus. Thanks
  16. markus
    1963 Cougar Research "100" mini bike info needed.
    I thought I had seen an actual photo or another member having one of these but maybe not :shrug: Member Apekillman is hooking me up with one he found recently and its making its way from PA down here to FL. Its a fixer-upper but for sure but does not appear to have been buggered up too bad...
  17. J
    TOTE GOTE info needed.
    I have a Tote Gote model #670 with a H60 Tecumseh engine. It has a lever adjacent to the motor on the right side. Is this a type of brake or an additional gear like overdrive? Thanks in advance for your knowledge......jak:smile:
  18. KustomKartKid
    Engine Powered Bike, Parts or Info Needed
    My kid is determined to put together a gas powered bike to use at school. I know a while back some of the Cali guys like Edwin and EvilEd were fooling around with these but haven't heard much lately. What is the story with these...does it need to be a 2 stroke or is there a small 4 cycle that...
  19. P
    What is this
    Ok so a friend of mine drop this off and ask me to see what I can do. I'm trying to find parts and any info would be grate. we r trying to get this going for his kid to ride this summer
  20. Briggster
    Ever heard of a Norseman Rocco "golden trophy" kart??
    I bought this kart at a personal property auction this weekend. Just looking for info on it. A quick google search didn't yield much. Thanks Briggster
