plate
  1. 45t
    Cat 400EL Eliminator fork plate decal?
    I'm almost to the end of my Eliminator build and I'm missing the fork plate decal. I did a search but could not find if anyone actually repopped these decals and was selling them. If anyone has one or knows where to get them, please let me know. thanks
  2. Pit Bug
    ARC Top Plate and Linkage
    I bought a couple parts I thought I needed but never did. I have an Arc Top Plate # DJ 1144 And a PMR Linkage Kit Both items together only. I paid $35.10 + shipping, but don't need them. $25 shipped, USA only Paypal preferred, PM for details .
  3. samevansjr
    Carb Insulator Plate
    I have a 6.5 Clone. Do you have to you use the carb insulator plate when you use this spacer after the carb? I'm running a Honda 200 max bore carb.http://www.nrracing.com/product-p/nrspacerman.htm
  4. Engine plate repair
    Engine plate repair
  5. taco fijole
    taco fijole
  6. taco fijole
    taco fijole
  7. Clayon
    PMR Engine mount plate
    Does that engine mounting plate from Hotrodminibikes help reduce vibrations? :shrug: Just kinda wondering. Thanks. :thumbsup:
  8. rpm
    Pro Mod gear reducer plate
    Price reduction $45
  9. Dragbikemini
    1.3 Stamped Rockers and Billet Guide Plate
    6 Hours run time. $15. ($26 new) Located Brewster, NY 10509
  10. rpm
    Prp mod gear reduction plate
    Pro mod gear reduction plate $50
  11. jbrewton
    Comet 330 outer bolt, washer, and plate
    Could use an original Comet 330 driver outer washer, plate, and bolt. Let me know? Thanks loads Similar to these:
  12. MB165
    Jackshaft plate F/S
    This is a new jackshaft plate for small frame engines. New 5/8"ID shaft bearings installed. This is a BMI item, and will work with the shaft I have for sale separatley. Clutch Mount with Jackshaft (03191), www.bmikarts.com : BMI Karts & Supplies : Go Karts Parts : Racing Go Kart Parts ...
  13. L
    Motor Mount Idea
    The mount on my mini bike was welded quickly and its not a very strong weld, which was done by the previous owner. I was wondering could i grind out the existing plate and instead of welding a new plate, just weld two 1/8" thick by 2" or 3" wide flat steel across the tubes and just mount the...
  14. Timmahhhhh
    Frijole 5 Degree Plate Issues
    I am waiting for delivery of a Taco Frijole Monster frame set with the 5 degree tilted engine plate. I plan to use a clone,like a 5.5 Carroll Stream or a 79cc Lifan (sorry,purists...) is this tilt going to affect the oiling at all? Thanks for any info.
  15. The Restore Kid
    69 Michigan cycle plate
    or maybe even a couple... :shrug:
  16. Timmahhhhh
    Allied Leisure Lil' Indian
    I'm going out this weekend to look at this Lil' Indian-I have a question or three: 1) When did they start making the two piece frames? I noticed this model is a somewhat larger two-piece frame- not like the originals,but I still like it. 2)Was a 6 hp Tecumseh an option on this model...
  17. T
    OldMiniBikes motor plate
    Just got mine in the mail today dident have any instructions were to drill the holes if anyone could tell me were the plate has to be to drill the holes i would appreciate it.
  18. fulcrumflyer
    Cat Kill Switch Plate Decals
    Three available. $13 each. PayPal only. Will be mailed via regular post from Las Vegas, NV. Plz PM.
  19. old-timer
    OldMiniBikes engine mount plate problem
    I just bought the OldMiniBikes mount kit to mount my Predator and it doesn't fit. I was trying to mount it up to my new Motovox and it's not even close. I was under the impression it would fit the DB as well as the Motovox:shrug: Not quite sure what I want to do now. I really hate to drill the...
  20. H
    CAT 400X Switch Plate
    Pretty Please?
