springs?
  1. H
    Compression Springs?
    I'm on the hunt for compression springs used in shocks/suspensions on these old minis. Taking a very rusted from end apart with heat, I unsprung the springs. I also want to play around a bit and make a front end more usuable for my weight and the design of the front end. Looking at OAL...
  2. Clayon
    What cam with 18lbs springs?
    Just wondering, what cam are you guys using with 18lbs vavle springs? :shrug:
  3. stevetheman
    Super bronc: de-gunking front springs?
    Hello all, So when I pulled the springs out of the fork, I think I figured out why the front supsensh' seemed to be seized. It looks like over the years the grease on the springs hardened into a nasty plastic-like crud on the spring, preventing the springs from compressing. :doah: Any...
  4. FirePowerMinis
    High lift, low pressure springs?
    I plan to run 1.3 rockers on a stock clone cam for a hi-torque/lo-rev build. What springs will take .290-ish lift and not wipe out a stock lobe? I guess I can have the cam MicroBlue'd and run 26lb, but want out cheap :)
  5. C
    do i need stiffer springs?
    ok,i have a 14cc head cut .065 with 1.2 rockers,ss valves and all do you guys think i need stiffer springs then the #26 also have an agk .276 cam in her,will i start floating around 8000 rpms?or sooner?:blink:
  6. MisterRoboto
    torque converter missing springs?
    i got this tc off a ohh60 and its rough but i got it apart and it doesnt have the springs/weights i tryed to look up parts for the maxtorque converters but the pics and listings i found looked like these ones dont have the springs. so is this missing the springs or does it not need them...
  7. D
    is it bad to mess with the throttle linkage springs?
    my 2.8 seems to have more power than i thought it would and it backfires at high rpms i had tightened up the linkage springs did i unknowingly deactivate the governor or something? :doah:
  8. J
    tecumseh 5.0 hp valve springs?
    I just removed the gov. on my POWER SPORT 5.0 and I'm wondering what springs I could throw in it to prevent valve float. Are there any from other brands that would fit the bill?
  9. Hothead79
    single or dual springs?
    Race Head, Level 4 Cylinder head (GX160 or 200 Honda Casting depending on desired compression), Ported and Milled to choice of compression ratio, Stainless high flow valves, OVERSIZE 27.5 mm intake w/ 4 angle valve job, Choice single (26lbs) or dual springs (55lbs), Aluminum Retainers w/split...
  10. OldMinibiker
    What Return Springs?
    Hi,(I did a search but with no luck) Hey what return spring(s) are you using on your clones? Have you found there to be differences among springs,do you have a preference of a certain type,strength etc? I ask cause the one hooked up on my clone pulls to much causing me to have to twist my...
  11. azndude3141
    does a minibike twist throttle already have built in springs?
    if no, then how would i attach a spring to the engine to return it to idle everytime i let off the accelerator. im a little confused. (yeah, im a noob and this is my first build, thats why im asking a question like every 10 mins. lol) oh and as always, THANKS FOR YOUR HELP...
  12. rgroves231
    Where to find springs?
    I am looking for a set of new fork springs. Mine measure 5-5/8", total diameter-just under 1-3/45". They thin out at each end to twist into holding position. Anyone know where I could find a pair? See pics, thanks
  13. Frank Bullitt
    Who makes the clone valve springs?
    Is there anything particularly special about them besides a "known" compression? I know it might sound stupid but couldn't a hardware store spring of the proper compression and dimensions be used? Metal fatigue after many compression cycles might be a problem. I ask this crazy question...
