did you check your crankcase bolts,they might be loose. Also check the breather to be sure it is working and not clogged. it should be easy to find another oil cap,it might be cracked or something.
also check does that fill have a o ring ? some do some dont . if you do need a new plug its easy any briggas one that looks like it will fit and even the tec one too :thumbsup:
