330 lift cam, 3.875 arc rod and Clements billet head $100 shipped
125ccCrazy Well-Known Member Apr 18, 2013 #1 Apr 18, 2013 #1 330 lift cam, 3.875 arc rod and Clements billet head $100 shipped Last edited: Apr 19, 2013
M Mikez3202 New Member Apr 18, 2013 #3 Apr 18, 2013 #3 Will me using that head make my engine overheat with no fins?
125ccCrazy Well-Known Member Apr 18, 2013 #5 Apr 18, 2013 #5 roccosbike said: Wow, Id like to get some of that head Click to expand... :doah: Mikez3202 said: Will me using that head make my engine overheat with no fins? Click to expand... as long as your moving you will be fine, just not meant to sit and idle for long periods...
125ccCrazy Well-Known Member Apr 20, 2013 #7 Apr 20, 2013 #7 this head is approx .400 deep from the gasket surface to the top of the chamber above the valves...
Slipnride New Member Apr 20, 2013 #9 Apr 20, 2013 #9 is the cam a custom grind and if so what rpm range?
125ccCrazy Well-Known Member Apr 20, 2013 #10 Apr 20, 2013 #10 Slipnride said: is the cam a custom grind and if so what rpm range? Click to expand... it's a welded and ground cam... properly set up it should pull 8000 no problem..
125ccCrazy Well-Known Member Apr 22, 2013 #12 Apr 22, 2013 #12 $25 for the rod plus ship and $30 plus ship for the cam..... $6 shipping either or both parts...
