Getting a flathead to fit inside some frames is a challenge. Here are some things to help:
Made a filter out of a 1.5 PVC end cap and removed 3/4 in height.
Move engine forward.
Slide rear tire back
Cut or remove rear fender
1/2 in rubber grommets or engine plate helps rear tank over rear fender or tire.
Still Having a hard time with getting flathead into bird frame. Will a mounting plate more ability to move engine forward even more, just touching rear tire?
Any suggestions on 3/4 gallon gas tanks with fixed pulsajet carbs? Cheap? Smaller tank?
