bajaheat upgrade
the best upgrade you can do to one of these bikes is the torque converter,and disable the govenern.if you cant afford a comet tav30,heres how to get way more to speed out of the bajaheat,remove both chains from the bike, take small chain off and big chain off rear sprocket. make these two chains into one long chain. now remove clutch and gear reduction plate. now replace clutch with sprocket close to engine and run chain from rear wheel to clutch,you my have to take a few links out and move rear wheel back to tighten chain once this is done now you have direct drive w/5 to1 ratio(10teeth clutch and 50teeth rear sprocket.with the bike set up like this its climbing ability is gone(5to1 is geared to low for quick take offs or hills) but if you dont do to much hill climbing like me and just like to run flat out this will get you up to like 40-45mph top speed try it your take off will be slow but topspeed is way higer,if you can find a 60 or 70 tooth rear sprocket you can get some of your hillclimbing ability back and a fasyer take off.7to1 ratio is best for all around riding:thumbsup:
