A couple other tips... Clean the inside of the upper tubes where the liner sits, especially if it was all greasy. You want full room for that liner to expand and make it easier for the next guy to pull them out.
When reassembling the springs, the cross pin in the lower fork tube just sits loose until it's up in the liner holding it together. Be careful when reassembling to keep it in place.
When putting the top spring retainer bolts back in place, you need to slide the lower tube up or down a bit until you feel the bolt go through the spring eye. Once through the eye, you'll know you got it because the lower tube won't slide up or down without some pressure, and should spring back.
Be careful removing the old caps and liners. Treat them as if replacements are not available. Real ones made of the right material are hard time come by. I used a set of replacement caps and liners once and they broke when assembling them. Too brittle. Wasted $50. Ended up using the old ones. They just work better and honestly, never wear out. If you don't have a need to remove the end caps, don't risk it.
