Baja heat 6.5hp no governor and won't start please help
Ok so I've had this baja heat for about 2-3years it's been running good and I decided to make it faster right before It started right up and then I took out the governor and put everything back on and now it won't start up it has spark and compression it just won't fire up the cams are dot to dot and it has new oil and gasoline and the rods are in there to id really appreciate it if you'd help me out
