Sorry guys I am 100% new to this anyways I got 2 bikes one baja with the front shocks and one minibike for $50 from this guy...
the baja has I guess what you call a jack shaft on it came stock like that...
My problem is when I swapped the motor out from the 6.5 to my really modified gx160 i expected to be scared seeing that it was my first time on one... well no the motor shakes bad but all the bolts are tight then I noticed the gear that is connected to the clutch chain and the actual drive chain is messed up the actual weld that holds the brace for you to bolt the pully to the frame is broken... my question is is that really needed or can I go straight from the clutch to the rear wheel or is there a way to fix this problem again really new so if I need to buy something just let me know what it is I would need thanks...
