Hey folks, I just bought this little bike from @Rlitcher the other day.
You typically only see modern late model mini bikes show up for sale around here, and most belong in the freakbikes section.
I couldn't believe this showed up for sale here. I only had to drive 9 miles each way to pick it up !
Shortest distance I think I've ever driven to buy a mini bike.
In looking at the different photos I've found on the Oldminibikes.com website, I believe mine to be a Bremer - however mine does not have the Bremer name cast in to it ( not that I've seen yet anyway.)
Mine appears to be the two stroke frame version.
I read where the 4 stroke frame used a 3hp Briggs and Stratton, but I can't tell from pictures, which 2 stroke motor came in these originally ?
@superflea @bremerman @markus and @sparkwizard do any of you know which 2 stroke engines were used on these ?
Here's a couple pf crude pics for now, but I will try to post some more this weekend.
If you zoom in on the second pic, with the frame folded up, you can see the motor mounting 4 hole pattern, for a two stroke engine.
Aside from my question about engine model needed, I also need to know the best way to clean up this aluminum frame ?
Thanks in advance.
Thanks in advance.
