Do your self a favor and use a block of wood not a chisel and when removing the starter clutch install the 4 screws this will make the tabs u are hitting a little stronger less chance to snap one off
Yes, that was incorrect information. The OP never replied back where he got that information or if he ever even got the starter clutch removed!
Michael
NOOOO!
Flywheel puller is bad! All it takes is a screwdriver prying gently on the case against the flywheel, and a light tap with a brass hammer...they usually pop right off! You don't want to hammer on the end of that shaft as the recoil needs to spin on it!
NOOOO!
CPLB is 100% correct. My son and I have NEVER used a puller on a flywheel with over 30 engines in the last 8 years. To the original poster (Racer)- did you not learn anything from all of the previous replies?
Michael
I bought a wrench set and crankshaft tapper. Flywheel removal has never been easier.
Tha crankshaft tapper thing is neat. Just slide onto the exposed end of the crank after the recoil sprag/clutch is off, pop it on the pointy end w/a hammer and the flywheel slides right off. It has a brass plug inside to protect the tip of the crank from being damaged. You don't have to hit it hard at all.
