Double pipe looks awesome!
That double pipe looks really good and the motor is almost in the right spot side to side. Can you return the pipe and have the pipe manufacturer adjust it or make you one with the pipes offset another inch or two farther over the motor side to side? Can someone bend it farther over with a pipe bender?Could you add a wedge shaped block where the header mounts to gain another inch? You see wedge shaped blocks used on the intakes of Tecumsehs used on the Rupp bikes with the slanted motor mounts instead of the angled intake manifold.
Anyway, your bike is going to be amazing and may deserve a custom header. Everyone knows that a mini chopper frame is not the easiest when it comes to clearances or interferences, but you've got that motor looking really good in there!.
