Bent valve train components are usually from piston to valve contact,your cam could be installed out of time,to much valve lift from to big a cam,wrong piston to rod combo,if you remove head you will probably see where the valve made contact with the top of the piston,you can always check a combo by putting a small amount of modelers clay on top of the piston and installing the the head and turning the motor over and check for clearence issues.:scared:
