I'm not sure if there's any way to test the coil, but you can eliminate all the other possibilities. It's probably not a spark plug, but it couldn't hurt to get a new one. Make sure the black wire coming off the coil isn't grounded to the motor, and finally check the clearance between the flywheel and the coil, it should probably be about 0.020". after all that's done, if you still don't have spark it's the coil.
