Hi Everyone,
Happy Friday!
I recently bought a year and a half old Coleman CT200U! It has been riding great and then I wanted to upgrade. I purchased the GPS Stage 1 Kit and after the install, the bike does not start. I purchased the new carburetor as well, because the newer models of the bike have a EPA approved carburetor that would not work with the Stage 1. When I try to start the bike, it sounds as if there is no ignition. It sounds the same as if I am pulling it while off. Only air is moving through. I do not think I am installing the new carburetor incorrectly. I am using the original plastic gasket in the back of the carburetor, and then the new paper one in the front. I have also tried various versions and combinations of these gaskets. I then decided to put back the old carburetor to test it. It would not start! I then thought this is a ignition issue. So, I removed the kill switch wire from the ground and it worked! So, I thought the issue is the kill switch. But then, I put back the new carburetor and tried to start it again without the ground, and it does not work again. It still sounds as if there is no ignition. I am at a loss now. Any advice would be greatly appreciated. Thank you all in advance!
All the best,
tryingmybest
Happy Friday!
All the best,
tryingmybest
