Comet 30 Series Torque Converter
What does switching the clutch springs on the driven pulley do? The stiffer the springs are the higher the rpm range is. But what is it doing differently? Shifting at higher rpms or engaging the drive pulley at a higher rpm? What's the benefit?
Shifting to high gear later. It's already engaged, and that happened with the driver.
The stiffer spring changes the point at which the driven starts feeling low enough torque on the gear side to allow it to decrease in diameter. It is said that this means RPM is higher- which is true. But it is acting on torque, not on centrifugal force like the driver is.
Well i swapped for 3300 rpm springs (yellow) because I thought I would have more power than the stock setup before it shifted. I also moved the the other spring to the 3rd hole and went from a 12T sprocket to a 10T. But I have a long delay before the wheels start spinning. Is that normal? What's causing it?
You're too high geared and too stiff on the torque sensing. I'd go back to the larger sprocket first, then if not satisfied, move the notch to the middle setting. I am not a big time expert on this stuff, just know what I know from fabricating a couple of drive systems.
As a novice, I follow one rule: Make changes one thing at a time. Takes longer, but at least you know where you made the error, or decision that yielded unwanted results.
Yeah that's how I originally wanted to do it so I could notice the difference. But I found my chain was all kinked up so I just did it all at the same time for the convenience.
The other sprocket is a 54T.
10 to 54 is extremely high geared. With that, and depending on total weight of machine, you'd be close to the high gear limit of a 6 or 7 HP engine and stock torque converter setup.
Since I am not there testing it with you, its hard to say anything with certainty, but you don't say if this is a big bike, heavy load, or tire diameter. But definitely go back to that 12 t sprocket and see what you have. Get new chain if you don't have it, and a chain tool if you don't have that.
JKautoFab
dave you got it backwards. going smaller on the front sprocket lowers the gearing, going bigger on the rear is what you are thinking of
yes 54 is too small for 13 inch tires unless you are pushing a lot of torque. keep the 10 tooth and get a larger rear sprocket
Sorry, JK, I did. Second time in recent history I've got that backwards. The rest of what I said about torque sensing still applies. Now that you pointed out my error, (sorry comeback kid) the fact that he moved the cam and changed the spring must have had even a larger impact.
The highest I've ever ran was a 13 to 60. With the weight of a kart vise mini bike, even that would be too high. I imagine the converter is never going to unload all of the torque like that.
Bikerscum
The reason I pointed you to the thread is it shows how the various springs (and weights) interact with each other. As far as fixing your problem, you never really said what your problem is. If you put stiffer springs, or lighter weights in the driver (engine pulley), you will raise the RPM at which the "clutch" engages. If you put stiffer springs in the driven, you will raise the rpm point at which the "gear shift" starts to take place.
My problem is that I moved the green spring into the 3rd hole, and swapped for the yellow garter springs and swapped to a 10T with a 54T axle sprocket. Seems like I need half throttle to get the wheels to start spinning.
Bikerscum
Your problem is the yellow garter springs. They are keeping the "clutch" from engaging until an rpm that's too high for your liking. Try one yellow spring & one stock spring. There's no harm in mixing them.
#19
So is that a bad thing or just personal preference?
#20
But I am understanding the idea behind the garter springs right? That I'll get more power from 1st gear due to getting into the powerband before shifting. Right? That's what I was going for.
