comet 400 clutch
I'm building a azusa kit, using a clone from HF, the comet clutch and rear sporket are not even close to lining up, if I flip the clutch they line up nice, will this clutch work this way?
it will be fine like that. just be sure to use a 5/16-24 x 3/4 bolt and washer (add a lock washer if you want to) on the end of the crank shaft to hold it on. with the bolt in the crank you don't need to use the set screws.
