He'd have to be to confuse an HS35 with an H35, and spray paint an engine without taping anything off. Because seriously, I'm about burned out with discussions on how someone is going to measure peak coil inductance down to thousandths of an inch of piston travel in the bore.
And maybe his version of "running good" is as accurate as his pre-paint prep, tape-out, or confusion between the rare HS35 motor and the more common HS40, or H35 motor. I experimented on acceptable parameters of time, and found that once you are plus, or minus .005 (advance, or retard) these engines start to lack power under load. When you get into the plus or minus .010 inch variance, you start shearing keys, and can't get them to accelerate very well off of idle.
I have an experimental version of a Stellar stand I made and didn't use. It's a welded on type of short stand to a bit of tubing that wraps around the frame. You can't really see that tubing, but it does rest on the bottom frame. It uses the single bolt that Stellar used. It works better than a couple of 2X4's, and almost as good as leaning it against the garage door. Yours if you want it.
