as ive been told about the bushing vs bearing/bushing vs full roller bearing blocks is really the application. if you are doing circle track, you want a roller side cover and bushing block, as the left turns pushes the oil towards the bushing keeping it lubed while the roller side keeps the clutch side okay during turns and picks up oil on the straights
if you are running equipment that doesnt move, full bushing blocks are fine, but for moving machines they arent a good idea.
double roller i would think be best for mini-bikes that are going to be leaned left and right. I wouldnt be as worried about the less material around the roller bearing unless i was pushing big numbers, in which case you could easily have a welder add aluminum around the bearing bore.
