When I was just a youngster (40 some years ago) I had a home built go cart that used #35 chain. Most people know that if you run your mini bike or go cart long enough that you either break your chain or the clip on your master link falls off and you need to put on a new master link. You always made sure to have an extra master link around since you never knew when one would fail.
40 years ago I remember running across a different style master link that used a pin going through a hole similar to what a cotter pin does rather than a clip. You can't modify a regular master link to do this because the center pin of the link needs to be a little longer for the hole for the cotter pin. This style master link seemed to last much longer that the normal clip style master link because there is no clip to fall off.
I've looked around on line and on E-Bay, but I haven't seen any of this different style master link. Does anybody remember this different style master link and if so, where can one obtain them today?
Thanks!
Jim
Thanks!
Jim
