I think anyone that owns a mini bike should watch this video. It's a small engine mechanic, and what he's seen in the last 2 or 3 years is incredible what this ethanol is doing to small engines. Not just Mini Bikes but Lawnmowers, Snowblowers, even Boats! And if you live in the Northeast like me, and have to put stuff away for the winter, if you don't treat the fuel before storing your machines, you can forget about starting the things come spring. I've actually been running the machines until all the gas was gone before putting stuff away. Now I've been hearing that thats not a good thing to do and that it's actually worse to do because it could cause rust on some of the metal parts, and cause and rubber parts like gaskets and fuel lines to crack and stuff. They're saying you should fill your tank, treat it with Fuel Stabilizer, let it run for ten minutes, then put it away. This guy say's to run everything at least once a month, maybe even every 3 weeks, just to make sure the gas is getting circulated, or the Ethanol in the gasoline will actually start to turn to water. I think this is why a lot of us are having carb problems lately. I'm on my second carb in the last 3 years?
Well watch if you want:
Talking About The Damage That Ethanol In Gasoline Does To Small Engines - YouTube
