In a separate thread where I talked about spacers; one of the fellows who replied mentioned that the bearings in his hub were loose and could be removed without the use of tools. Not a good situation! The body of a bearing is designed to remain stationary while the inner hub (which rides on the steel balls within the bearing assembly) is supposed to do all the rotating. If the body of the bearing does not remain stationary; it too will eventually begin to rotate. The result being a wearing out of the inner diameter of your hub and a premature failure of the entire bearing. However, there is a simple trick that a lot of us "old-timers" use to snug up a bearing in a hub. It is not an ideal fix but it's 100% better than a sloppy fit between a bearing and a hub. Take a small chisel and make six to ten dimples around the inner surface of your hub. Make them pretty deep. Then go ahead and press your bearing in. I've attached a few pictures to illustrate what I'm describing. Hope this helps. Ogy
