After much research and development,the new TM Frijole Series II is on it's way to production.With a wheelbase of just 36",slightly pullback bars,simple construction and machine welded components,the final production model will be ready in early September.Construction is made with seamless .065" tubing and the motor mount plate(1/8"thick) is slotted to take the standard mounting configuration offered by most older lawnmower or edger engines,can be fitted to your specs on motor mount location(fore and aft),and also attached for LH or RH drive.The footpegs you see in this 1st production model are added for my personal fit(my knees hit the handlebars with footpegs up front)but these kits are offered with or without footpegs,your location or choice.The scrub brake is located to operate with the standard 5" wheel/tire(410/350),and I trimmed the pedal end down for my personal application.The seat mount is set in it's position for a standard Frijole seat and undrilled (if you want to add your own style).
These are made in California,come in kit form,and include the Frame,scrub brake,motor mount,footpegs,fork bolt with nut,and forks.
Cost is $250.00 + shipping.
If you have questions,send a PM to:RAWTONE at TacoMoto ENT.
He is also working on a seat to fit this model…….
We build the hard to find parts necessary to get your project finished or on the way.
regards,Joel
regards,Joel
