Fuel pump?
if your tank is lower than the carb you will need a fuel pump. otherwise you are better off with gravity feed. A lot of carbs are designed to be gravity fed. If you use a fuel pump it may have enough pressure to push open the needle/seat and flood the carb. Mikuni have some small needle seat sets to allow fuel pump operation.
You only really need them if your tank is lower than the carb inlet, or if the motor uses fuel faster than gravity can feed it.
