Thanks! But I mean the actual folding metal part of the foot peg ya got on the frame? I've seen bolt on ones, but I want weld on ones like those.
Also, do you know or could measure from the top of your engine frame plate to the to the bottom of the handlebars? I'm wondering if you have the same amount of clearance as I do on my (believed to be) 250X frame.
What engine is that/how mant horsepower? I have a 3.5hp honda gx110 I think from a pressure washer I was going to use, but that may not have quite enough power for me...
Must be someone cut off the factory welded pegs from your frame. I made two close up shots so you can see how they are done. 7/8 tubing that is flattened on one edge. A companion tube with what appear to be two plates, about 1.25 inches long, is notched/welded into the frame about an inch in front of the main tube welds. A heavy duty rivet is used to attach the peg to the notched and welded piece. I can dig around my photos to find more, if you need more detail.
The distance from the motor plate to the bottom of the frame is 13.25" measured at the notch for the chain. I built a Tecumseh OH195 engine for this bike. The crank is from an OH60 as is the intake and carb. I think it'll be about 6.5 hp once the header is installed. I have one inch clearance between the top of the plug and the frame rail. I haven't measured, but I have 6.5 predators on my 400s, and clearance is tight but they fit. Access to fuel caps is tricky--hemi preds require a new cap and non-hemi pred caps come off easy (I have one of each). I imagine much of the same hop up stuff you can do to a 190 or 200 will work--experts will know--there is a tech section on Hondas and clones, post there. To be honest, I put a 5hp GC190 from a pressure washer on a Manco Thunderbird with a 54 tooth sprocket and it was WAY more than it needed--you may be just fine.
Hope this helps.
