OK so I'm thinking on building a predator 212hemi to the max. I'd like some help from the experts please. I'd like to remove the governor, replace flywheel, replace valves, springs, cam, rod, even the carb if needed. Or anything else one seems necessary. So my question is which part numbers should I use to make the best and safe motor. Thanks for all the ideas and advice
Also I have some Honda gx200 heads that I can milling down. I heard .005 is the best with a thinner gasket. But more input is better.
