Mini baja gas tank questions
buckeye
I've been watching for one of these. The helo tank is as cheape as I have seen.
Maybe a dumb question but, can you get that graffic off without repainting??
#31
We are talking about taking the original fake tanks off the Mini Baja and making them real tanks. Is that something you think you can do? I dont know if the metal is too thin or not. A tank like this one. It would also need a functioning cap and petcock.
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices . Trying to make it look as close to original as possible. Randy
Does the frame protrude up into the fake tank? I can DEFINITELY weld a bottom and a cap onto that tank.
#32
#35
Here's what it looks like now with a new Greyhound 6.5 hp "Clone":
Here's a side pic with the stock Lifan 6.5 hp engine and also before I put the headlight back on:
#36
Tank looks good but I think the open space under it will drive me crazy. I may have to make a custom helmet holder. Maybe a skull it can sit on while not in use. Is there enough room for a helmet there? Old school metal flake open face of course. Randy
#38
Yeah, I wasn't too crazy about all that open space between the tank and engine myself. I eventually painted the Greyhound tank that came on the engine black, added a chrome cap for a little "bling", and put it back on the motor. I'm thinking about maybe using it as a reserve tank and put a valve between the two tanks.
Before without Greyhound tank:
After with Greyhound tank:
I guess you could mount a helmet holder in there. :hammer: :weld: :grind:
#40
The china bike gas tanks do not accept a standard petcock, threads are close but don't jive but since yours is a repop for a Chaparral I would think a standard 3/8" fitting would work. I forced one with thread sealer for my DB and it doesn't leak after 3yrs but I would tap it or replace it if I do it again. The bicycle tank petcocks also do not flow enough fuel to keep up with a good size engine.
