Ok guys, I have had this crazy idea in my head for a while now and I can't seem to shake it..... so I'll probably have to build it, if it's feasible :grind:.
I want a single track trailer for my mini with a matching wheel and tire, but I want the wheel driven. So after I do the tandem rear wheels, the trailer would make it an inline 4x4 :doah:. There isn't really any way to do an overrunning clutch on a trailer, so the wheel speeds have to match each other to avoid quirky handling. The only way to do this (in my mind at least) is to have the distance from the bikes rear axle to the trailer pivot the same as the pivot to the trailer axle. This should, in theory, keep the trailer tire exactly following in the track of the bikes rear tire(s). The plan is to run a chain from the rear tandem wheel pivot shaft to the trailer pivot, through a u joint, and another chain from there to the trailer wheel.
So, cool or stupid?
