Was told this was a Cat. I haven't been able to find a comparable picture yet. Body used to be at some point a purple color (can see in pics poking thru scrapes in the blue). Briggs motor Model 91202 Type 0016 01 Code 960827FA. Handlebars are a bit tweaked, scrub brake, having some issues with the throttle, prob needs some carb work, chain keeps popping off. How original does this look?
Was told this was a Sears. NO clue what is up with the jackshaft (the clutch is on there), some shoddy weld work on the front fork (on metal plate), rear band brake, rear gas tank is intact, non running so far. It has a 5hp engine #'s on top HS50 57244P SBR517CB. Obviously needs entire throtle setup, engine isn't even fully mounted..this may take me a bit to even start messing with.
