Hummer shop press:
so I have this jacked up Mickey/KOL frame:
looks like the used a jack and something rectangular across the top bars to raise it up some for who know what kind of engine. you can see 4 divits in the top tubes at the bottom.
My little shop press is too small, I figured I'd try to use the weight of my SUV to squish it back down
Tools for this were some 2x4's in various pieces, 2 hammers, the plates from my shop press, a floor jack.......and a Hummer H3
I used some 2x4's under the frame becuase of the kickstand and scrub brake, this allowed it to sit flush, I made sure the went the length of the frame so it woudl no bow on the bottom. since I sticks out pretty far and a somewhat small area I used the receiver of my hitch so I would not be crawling under the truck. its sits pretty high already so I used some 2x4's to both take up slack and have some give in hopes of not kinking the top ob the bar, the steel plates took up more space.
It was just high enough that I saw it drop the frame a touch but the it just started to rest on the leaf springs and I could see the Bilstiens start to compress so I then used the hammers for a few stiff whacks on the steel plate to help a little.
was pretty quick and easy, got it in better shape but will still have to deal with the divits from when they jacked it up. but I'll work on that when i tackle replacing the rear axle mounts they moved :doah: I know it doesn't really look it in this pic but I actually dropped the tubes around an half of an inch and its much straighter than it was, kinda hard to judge what it is supposed to be, they weld the frame together at the top under the seat and quality control apparently was NOT an issue at the KOL factory:wink:
