Engine numbers are: HM80-155174 Ser 0011C
This engine is off of a Super Bronc that me and the boy are trying to resurrect. I replaced all of the leaking fuel lines and removed and cleaned the carb. We got it started but it won't run for very long. I started it on choke and then take it off choke immediately before it dies. If you try to throttle it up quick it will sputter and die. It won't recover and keep running. I tried several adjustment while it was running but if you move anything it will sputter out and die. It sounds decent when it's running so I'm not sure what the problem is.
What can you tell me about the engine from the serial number?
Thanks
Thanks
