New hemi predator. Never started. Has been disassembled, clearances checked. Big end of rod opened up to .002+ oil clearance. Governor removed, low oil level sensor removed. Holes drilled and tapped and plugged. Has Arc top plate and throttle linkage, box stock pipe and rlv silencer. 10.8 valve springs. Valve cover drilled and tapped for pulse fitting, fuel pump. Brand new hilliard extreme duty clutch. .010 Honda head gasket, ruixing carb, arc jet kit. Arc filter adapter and filter. This is brand new never ran, never had oil in it. $375 shipped or I will trade for a big wheel bike. I can sweeten the trade depending on the bike by adding a new Chinese tav2. All parts are brand new. I can text pictures later this evening. As always you can pickup in Grandville michigan. PayPal only.
