I've decided the junk 8hp briggs flathead I bought is in pretty bad shape and probably not worth trying to find a crank and rod for it. Cracks in both sides of the block, bent exhaust valve, ruined crank/rod, nicked up intake cam lobe... So I'm going to use it for my exposed crank project I've been thinking about for a while. First I pretty much just hacksawed the bottom of the engine off, leaving four bolt holes to hold the side cover on. The engine will sit on it's side when finished, as it is in the pictures. I'll have to make up a mount of some kind and bolt it to the engine. Cyl. lubrication will be dripped through a hole in the side of the cyl, probably between the valve springs. I think i'm going to remove the oil ring since it will no longer serve a purpose. Rod will have a grease cup threaded into it somewhere. I'll clean up the rod and crank as they are scored up somewhat. I'll drill a hole through the rod where the wrist pin is so I can oil that. Not sure about the crank bearing/bushing on the flywheel side. That might be tough to get to with the flywheel in the way. The output side rides in a ball bearing, so I'll just oil that and it should go forever. I don't want to use modern looking grease fittings on anything. As for the valves and cam, I'm going to use much lighter valve springs. I may make a wick that rides on the lobes to keep them oiled up. Since the exaust valve is bent and the intake and exaust valves are the same size, I may use the intake valve for the exhaust and use a tecumseh valve I have that fits the intake seat but is shorter and won't reach the lifter. Then I would use a very light spring on the intake valve without a lifter, the suction of the engine pulling the valve open, as was common on many early engines. Maybe I can bend the exhaust valve back enough to use it. I'm going to use two head gaskets together to lower the compression and take some load off of everything. I think I'll use the stock intake with a 5hp tecumseh carb. I might eventually try making my own carb for it. With everything detuned and running at real low rpm's, everything should hold together pretty good. Eventually it would be nice to built a 1/4 scale curved dash oldsmobile or similar early automobile to put this in, but i'll just see if I can get the motor running first. There's some pics of the engine before and after, and also, my new briggs crank case snack bowl. I'll clean up around where I made the cut so it looks a little better.
