ok i build a clone awhile back runs great getting ready to rebuild it to get it ready to race it on a kart in an open class in texas. i have billet rod and flywheel 18cc head going to port match an tillotson addapter to the head and do a little more porting. .009 head gasket race plug. block vented to valve cover. block mambe jr cam with 1.2 rockers and 26lb springs. im looking to twist about 6900-7100 im looking at getting retainers and locks, lashcaps, honda rocker studs cm pushrods billet lifters black mamba 246 duration cam put a tilotson carb on alky and use a honda wrist pin
do u guys suggest ss valve or will my hondas be good and running stock clone piston, problem? and running 1.2 stamped rocker with 26lb spring valve float or coil bind?
if you guys could help me out that would e great having the motor dynoed in feb before the race and tunning the carb in the process
