Peltier mobule, blower and heat sink cooling
A cheap engine mod could be done even on a stock motor. Cutting a rectangle into the top of the air box to add a peltier cooling method to the carburetor would do fine. make a rectangle box with an open so that it blowers cool air through the air. the box must consist of 1) Heat sink 2) peltier module 3) blower motor. the peltier module will create the cooling the heat sink will expand the cold surface, and the blower will create the cold air stream, and adding a battery will produce its function. My motor will have a charger coil,charger, lights and a peltier cooling method I thought up like the above.:smile:
