Predator 212cc throttle bracket to bypass Governor
#22
No need to swap keys , file it down , i can't remember the specs off hand but I think for every .006 = 1 degree advanced , I'd try 6 deg first , may can go 8 ? There is info out there for this , one of the pro's will chime in soon !!
#23
I've seen alot of write ups use an 8 degree timing key on the predator 212 motors and GX200 motors. I think I'm going to order one since they're only $8. I don't really have access to a file and vice and all that. Just basic hand tools. Is there any other racing tricks/mods to get just a little more out of it? I'm going to try mixing a half gallon of 93 premium and half gallon of 110 octane racing fuel. My buddy is letting me have a whole gallon. Just trying it out.
#24
Don't bother with the fuel. They don't have enough static compression to need it. You may actually get inefficient combustion from running too high of an octane.
8 degree advance, re jet, pipe and air filter kit. Can be done for approx $75 and two hours of your time.
Sent from my Texas Instruments Speak and Spell...[emoji2]
#25
I have a .36 & .37 main jet with 140 emulsion tube, high flow air filter kit, and a header/muffler for xmas to be installed. Going to order the timing key now. My buddy just offered the 110 fuel to see how it would run.
#28
Like minibikin said with those up grades it will run great with 87 octane :thumbsup:
#36
Ok I have a question about the governor lever. It has 3 holes for which to attach the spring. It was already set in the middle hole. Which hole could I use for more rpm range? Left, right or middle?
