Predator Gas Cap won't clear frame? Here's the fix
You can reduce the height of the gas tank cap on the Predator 212 but taking the cap apart and cutting the white plastic underneath flush with the top of the metal. I have the new Predator 212 CA version with screw in cap. Undo the chain that connects to the screen filter and turn cap upside down. Take a straight edge screwdriver and carefully pry off the black cap cover. You will find a white plastic double ring. Cut the white plastic down to the existing metal on the top of the cap. You now have reduced the height of the cap so that it will clear the top bars of the frame. I saw this on a video from a guy in New Zealand. If you need more instructions or would like some pics of the final product contact me.
Thanks for the how to. Sometimes that's all you need is that little bit more.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
