next i mounted the brakes, as people are often asking me to make things for their projects, I like to make some of this stuff bolt on, or repeatable.. i used one of the brackets i had test cut and found one that matched the angle of the rear brace... on this particular bike... it fit nice enough, but i needed to make some modifications to it, in order to make it fit this build... i moved the caliper down, so it fits the rotor size perfectly and also out further away from the wheel, to give a little more space...
as you can see in the pic, it did clear the wheel, but since i wanted to move it in toward the axle (so that the full pad contacts the rotor), i also moved it out further away from the wheel, i will clean this bracket up better later
