My son and I are doing our first clutch preventive maintenance on a used mini he bought last weekend. It is a "Maxi-Torque" 3/4" shaft, 12- tooth, mounted on a Tecumseh OHH60 6HP engine. It seems to have reasonably good performance, and I have not noted anything particularly amiss, however I have nothing to compare it to. We opened it up, blew it out with compressed air, wiped off the shoes and the inside of the bell housing, and lubed the clutch bushing. Anything else that I should be looking for? I noticed that the shoes are not perfectly flat/smooth, and do have some slight unevenness and ridges to them. In addition, the texture in some areas is smoother and shinier. Is that an indication of uneven wear? How much is allowable and to be expected?
Thank you for your help to this newbie...:wink:
